Saltar al contenido principal
Asus UL80J Keyboard Replacement
Qué necesitas
  1. Asus UL80J Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Place laptop face down with battery facing up.
  2. Asus UL80J Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide unlock button to the right.
  3. Asus UL80J Keyboard Replacement: paso 3, imagen 1 de 3 Asus UL80J Keyboard Replacement: paso 3, imagen 2 de 3 Asus UL80J Keyboard Replacement: paso 3, imagen 3 de 3
    • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
  4. Asus UL80J Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
  5. Asus UL80J Keyboard Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    • Gently pry the keyboard up. This will allow you to unclip the keyboard.
    • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
    • Unclipping sounds are normal.
    • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
  6. Asus UL80J Keyboard Replacement: paso 7, imagen 1 de 1
    • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
    • Remove the tape from the ribbon cable if needed and remove the keyboard.
Conclusión
Kateryna Turchenko
Miembro Desde 02/20/17
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S2-G4, Lacy Spring 2017 Miembro de USF Tampa, Team S2-G4, Lacy Spring 2017
USFT-LACY-S17S2G4
Miembros de 3
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 477
