Saltar al contenido principal
Asus UL30VT-X1 Battery Replacement
Qué necesitas
  1. Asus UL30VT-X1 Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus UL30VT-X1 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over onto the back. (Second Image)
  2. Asus UL30VT-X1 Battery Replacement: paso 2, imagen 1 de 2 Asus UL30VT-X1 Battery Replacement: paso 2, imagen 2 de 2
    • Locate the two battery locks. (First Image)
    • The battery lock on the left will need to be unlocked first which is done by pushing the lock to the left. (Second Image)
    • A red line should show which indicates it is unlocked.
  3. Asus UL30VT-X1 Battery Replacement: paso 3, imagen 1 de 1
    • Unlock the right lock by moving it to the right while simultaneously pushing upwards on the battery.
    • The battery should slide out of place.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 297
