Saltar al contenido principal
Asus U56E-BBL6 Optical Drive Replacement
Qué necesitas
  1. Asus U56E-BBL6 Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Optical Drive Replacement: paso 2, imagen 1 de 1
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Optical Drive Replacement, Back Panel: paso 3, imagen 1 de 2 Asus U56E-BBL6 Optical Drive Replacement, Back Panel: paso 3, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Optical Drive Replacement: paso 4, imagen 1 de 1
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Optical Drive Replacement, RAM: paso 5, imagen 1 de 1
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Optical Drive Replacement: paso 6, imagen 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: paso 6, imagen 2 de 2
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Optical Drive Replacement: paso 7, imagen 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: paso 7, imagen 2 de 2
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Optical Drive Replacement, Keyboard: paso 8, imagen 1 de 1
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Optical Drive Replacement: paso 9, imagen 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: paso 9, imagen 2 de 2
  10. Asus U56E-BBL6 Optical Drive Replacement: paso 10, imagen 1 de 1
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Optical Drive Replacement: paso 11, imagen 1 de 1
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Optical Drive Replacement: paso 12, imagen 1 de 1
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Optical Drive Replacement: paso 13, imagen 1 de 2 Asus U56E-BBL6 Optical Drive Replacement: paso 13, imagen 2 de 2
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  14. Asus U56E-BBL6 Optical Drive Replacement, Optical Drive: paso 14, imagen 1 de 1
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  15. Asus U56E-BBL6 Optical Drive Replacement: paso 15, imagen 1 de 1
    • Remove the optical drive by sliding it out from the case.
Conclusión
Josiah Allard
Miembro Desde 10/26/18
733 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 198
