Saltar al contenido principal
Asus U56E Laptop Screen Replacement
Qué necesitas
  1. Asus U56E Laptop Screen Replacement, Screen: paso 1, imagen 1 de 2 Asus U56E Laptop Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Position the laptop on a flat, stable surface, with the underside facing upward.
  2. Asus U56E Laptop Screen Replacement: paso 2, imagen 1 de 3 Asus U56E Laptop Screen Replacement: paso 2, imagen 2 de 3 Asus U56E Laptop Screen Replacement: paso 2, imagen 3 de 3
    • Make sure the laptop is unplugged before removing the battery to avoid risk of electric shock.
    • Slide the two battery lock switches toward each other.
    • Lift the battery to remove it from the laptop.
  3. Asus U56E Laptop Screen Replacement: paso 3, imagen 1 de 3 Asus U56E Laptop Screen Replacement: paso 3, imagen 2 de 3 Asus U56E Laptop Screen Replacement: paso 3, imagen 3 de 3
    • Remove the 3 Phillips #00 screws holding on the back cover of the laptop.
    • Lift the cover, exposing the laptop hard drive and RAM.
  4. Asus U56E Laptop Screen Replacement: paso 4, imagen 1 de 2 Asus U56E Laptop Screen Replacement: paso 4, imagen 2 de 2
    • Remove the eight small screws holding the hard drive in.
    • The hard drive cover can now be removed by lifting the tab on the left.
  5. Asus U56E Laptop Screen Replacement: paso 5, imagen 1 de 1
    • Gently slide the hard drive left toward the edge of the laptop, then lift up to remove it.
  6. Asus U56E Laptop Screen Replacement: paso 6, imagen 1 de 2 Asus U56E Laptop Screen Replacement: paso 6, imagen 2 de 2
    • Remove the 4 Phillips #00 screws around the RAM.
  7. Asus U56E Laptop Screen Replacement: paso 7, imagen 1 de 2 Asus U56E Laptop Screen Replacement: paso 7, imagen 2 de 2
    • Remove the 10 Phillips #00 screws from the bottom of the laptop.
    • Remove 10 Phillips #000 screws from under the battery.
  8. Asus U56E Laptop Screen Replacement: paso 8, imagen 1 de 2 Asus U56E Laptop Screen Replacement: paso 8, imagen 2 de 2
    • Slide the optical drive out of the laptop.
    • Gently lift the rear plastic hinge cover to separate it from the laptop.
  9. Asus U56E Laptop Screen Replacement: paso 9, imagen 1 de 3 Asus U56E Laptop Screen Replacement: paso 9, imagen 2 de 3 Asus U56E Laptop Screen Replacement: paso 9, imagen 3 de 3
    • Remove the 3 Phillips #000 screws from each side of the hinge (six screws in total).
    • Gently lift the thin plastic cover from each side, exposing the laptop hinge.
    • Be aware of the thin cables still connected to the screen.
  10. Asus U56E Laptop Screen Replacement: paso 10, imagen 1 de 2 Asus U56E Laptop Screen Replacement: paso 10, imagen 2 de 2
    • Gently lift around the perimeter of keyboard to separate it from the laptop body.
    • It may help to use a Plastic Opening Tool.
    • Be careful not to pull too hard on the keyboard - It's connected to the motherboard with a thin ribbon cable!
  11. Asus U56E Laptop Screen Replacement: paso 11, imagen 1 de 3 Asus U56E Laptop Screen Replacement: paso 11, imagen 2 de 3 Asus U56E Laptop Screen Replacement: paso 11, imagen 3 de 3
    • Pull the display connector straight up to remove it from the motherboard.
    • Carefully detach the white and black WiFi antennas from the wireless adapter.
  12. Asus U56E Laptop Screen Replacement: paso 12, imagen 1 de 1
    • The screen can now be safely removed from the laptop.
Conclusión
Una persona más ha completado esta guía.
David Zilar
Miembro Desde 09/29/15
167 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-5, Green Fall 2015 Miembro de Cal Poly, Team 14-5, Green Fall 2015
CPSU-GREEN-F15S14G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 1,376
