Saltar al contenido principal
Asus Transformer T100 Button Module Replacement
Qué necesitas
  1. Asus Transformer T100 Button Module Replacement, Rear Cover: paso 1, imagen 1 de 2 Asus Transformer T100 Button Module Replacement, Rear Cover: paso 1, imagen 2 de 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Button Module Replacement: paso 2, imagen 1 de 2 Asus Transformer T100 Button Module Replacement: paso 2, imagen 2 de 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Button Module Replacement: paso 3, imagen 1 de 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Button Module Replacement: paso 4, imagen 1 de 2 Asus Transformer T100 Button Module Replacement: paso 4, imagen 2 de 2
    • Remove the rear casing.
  5. Asus Transformer T100 Button Module Replacement, Button Module: paso 5, imagen 1 de 1
    • Unclip the white connection clip using a pair of tweezers.
  6. Asus Transformer T100 Button Module Replacement: paso 6, imagen 1 de 2 Asus Transformer T100 Button Module Replacement: paso 6, imagen 2 de 2
    • Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
  7. Asus Transformer T100 Button Module Replacement: paso 7, imagen 1 de 1
    • Gently fold the connection apparatus back away from your work area.
  8. Asus Transformer T100 Button Module Replacement: paso 8, imagen 1 de 3 Asus Transformer T100 Button Module Replacement: paso 8, imagen 2 de 3 Asus Transformer T100 Button Module Replacement: paso 8, imagen 3 de 3
    • Remove the screws using a Phillips Head #1 screwdriver.
    • Remove the power button module.
Conclusión
4 personas más completaron esta guía.
Taylor Pantiga
Miembro Desde 04/14/14
1,596 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-31, Maness Spring 2014 Miembro de Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Miembros
6 Guías creadas
Un comentario
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
Rudolf Guys - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 5,967
