Saltar al contenido principal
Asus Transformer Pad Infinity LCD Display Replacement
Qué necesitas
  1. Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: paso 1, imagen 1 de 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: paso 1, imagen 2 de 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: paso 1, imagen 3 de 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity LCD Display Replacement: paso 2, imagen 1 de 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity LCD Display Replacement: paso 3, imagen 1 de 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity LCD Display Replacement: paso 4, imagen 1 de 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity LCD Display Replacement: paso 5, imagen 1 de 1
    • Once removed, replace the LCD display back onto the glass screen (the new screen may or may not have new adhesive depending on where you got it.
    • If it doesn’t, make sure you secure it with the screws safely).
Conclusión
Allison Poh
Miembro Desde 10/20/15
549 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,150
