Saltar al contenido principal
Asus Transformer Pad Infinity Glass Replacement
Qué necesitas
  1. Asus Transformer Pad Infinity Glass Replacement, Glass: paso 1, imagen 1 de 3 Asus Transformer Pad Infinity Glass Replacement, Glass: paso 1, imagen 2 de 3 Asus Transformer Pad Infinity Glass Replacement, Glass: paso 1, imagen 3 de 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity Glass Replacement: paso 2, imagen 1 de 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity Glass Replacement: paso 3, imagen 1 de 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity Glass Replacement: paso 4, imagen 1 de 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity Glass Replacement: paso 5, imagen 1 de 1
    • Once removed, replace the glass screen back onto the LCD display.
    • The new screen may or may not have new adhesive depending on where you got it. If it doesn’t, make sure you secure it with the screws safely.
Conclusión
Una persona más ha completado esta guía.
Allison Poh
Miembro Desde 10/20/15
549 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
Miembros de 3
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 849
