Saltar al contenido principal
Asus Transformer Pad Infinity Charging Port Replacement
Qué necesitas
  1. Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: paso 1, imagen 1 de 2 Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: paso 1, imagen 2 de 2
    • Take off the screen and the big motherboard.
  2. Asus Transformer Pad Infinity Charging Port Replacement: paso 2, imagen 1 de 3 Asus Transformer Pad Infinity Charging Port Replacement: paso 2, imagen 2 de 3 Asus Transformer Pad Infinity Charging Port Replacement: paso 2, imagen 3 de 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  3. Asus Transformer Pad Infinity Charging Port Replacement: paso 3, imagen 1 de 1
    • Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
    • Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
  4. Asus Transformer Pad Infinity Charging Port Replacement: paso 4, imagen 1 de 1
    • Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
  5. Asus Transformer Pad Infinity Charging Port Replacement: paso 5, imagen 1 de 1
    • Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
Conclusión
Una persona más ha completado esta guía.
Allison Poh
Miembro Desde 10/20/15
549 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,094
