Saltar al contenido principal
Introducción
Are you unable to connect to any WiFi connection? If so, then you might be experiencing a faulty WiFi card. This guide will take you through all the steps required to replace your Asus Flip Book WiFi card.
  1. Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver. Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver.
    • Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver.
  2. Remove the back cover of the flip book by gently using a metal spudger. Remove the back cover of the flip book by gently using a metal spudger.
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Unscrew the battery from the motherboard using a phillips head J000 screwdriver on the 3mm screws.
    • Unscrew the battery from the motherboard using a phillips head J000 screwdriver on the 3mm screws.
  5. The battery comes attached to the motherboard and needs to be disconnected before you can remove it. Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
  6. The WiFi card will be covered by tape and attached to the motherboard.
    • The WiFi card will be covered by tape and attached to the motherboard.
    • Remove the tape from the WiFi card.
  7. Unscrew the WiFi card with a JIS #000 screwdriver. Remove the motherboard connection from the WiFi card with tweezers. Pull out the WiFi card.
    • Unscrew the WiFi card with a JIS #000 screwdriver.
    • Remove the motherboard connection from the WiFi card with tweezers.
    • Pull out the WiFi card.
Conclusión
Alejandro Lopez
Miembro Desde 15/02/18
620 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S17-G2, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 3
Últimos 30 Días: 17
Todo El Tiempo: 146
