Saltar al contenido principal
Introducción
If you are having trouble identifying what might be causing a problem on your flip book, it might point towards a faulty motherboard. This guide will explain all the steps required to safely remove the motherboard and all connections to it and replace it.
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver. Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver.
    • Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver.
  2. Remove the back cover of the flip book by gently using a metal spudger. Remove the back cover of the flip book by gently using a metal spudger.
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Unscrew the battery from the motherboard using a phillips head J000 screwdriver on the 3mm screws.
    • Unscrew the battery from the motherboard using a phillips head J000 screwdriver on the 3mm screws.
  5. The battery comes attached to the motherboard and needs to be disconnected before you can remove it. Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
  6. The motherboard has various components connected to it that you will need to disconnect to replace. Disconnect the components from the motherboard with tweezers. Refer to the images for which components need to be removed. The connections highlighted in yellow are easily removed by lightly pulling, If there is tape on it, simply remove the tape.
    • The motherboard has various components connected to it that you will need to disconnect to replace.
    • Disconnect the components from the motherboard with tweezers. Refer to the images for which components need to be removed.
    • The connections highlighted in yellow are easily removed by lightly pulling, If there is tape on it, simply remove the tape.
    • The connections in red require you to lift up the white latch securing these connections. The white latch lifts upward easily, afterwards simply slide out the connecting cable.
    • The connection in orange is similar to the connections in red, except the black part is the latch. Like before, flip it up and slide out the cable.
  7. Unscrew the 3mm and 6mm motherboard screws from the device using a Phillips head J000 screwdriver. Remove the motherboard from the device. Remove the motherboard from the device.
    • Unscrew the 3mm and 6mm motherboard screws from the device using a Phillips head J000 screwdriver.
    • Remove the motherboard from the device.
Conclusión
Una persona más ha completado esta guía.
Alejandro Lopez
Miembro Desde 15/02/18
620 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S17-G2, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 36
Todo El Tiempo: 526
