Introducción
Are you experiencing issues powering on your flip book? Is it losing it's charge very quickly? If so, this guide will help you replace a faulty battery in a few easy steps.
  1. Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver. Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver.
    • Remove the back 6mm and 8mm screws with a phillips head J000 screwdriver.
  2. Remove the back cover of the flip book by gently using a metal spudger. Remove the back cover of the flip book by gently using a metal spudger.
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Unscrew the battery from the motherboard using a phillips head J000 screwdriver on the 3mm screws.
    • Unscrew the battery from the motherboard using a phillips head J000 screwdriver on the 3mm screws.
  5. The battery comes attached to the motherboard and needs to be disconnected before you can remove it. Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Conclusión
Alejandro Lopez
Miembro Desde 15/02/18
620 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S17-G2, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 7
Últimos 30 Días: 39
Todo El Tiempo: 460
