Saltar al contenido principal
Asus Transformer Book T100TAM-C1 Back Panel Replacement
Qué necesitas
  1. Asus Transformer Book T100TAM-C1 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 Asus Transformer Book T100TAM-C1 Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the tablet portion of the device from the keyboard by pushing the large silver button near the base of the tablet. Pull up on the tablet to remove from the keyboard.
  2. Asus Transformer Book T100TAM-C1 Back Panel Replacement: paso 2, imagen 1 de 2 Asus Transformer Book T100TAM-C1 Back Panel Replacement: paso 2, imagen 2 de 2
    • Insert the iFixit Opening Tool into the seam of the back tablet casing and gently pry upwards. With enough force the clips will release on the back tablet casing.
    • Make sure to insert the tool in the seam between the black and gray portions of the backing. If the tool is inserted between the screen and the black portion then the screen may crack.
    • Move the iFixit Opening Tool along the seam until the entire backing is removed.
    • Be careful and try not to use too much force while taking off the backing because you may damage the clips. If you damage the clips the backing will not fit properly back onto the tablet.
Conclusión
Brody Moore
Miembro Desde 09/06/18
807 Reputación
7 Guías creadas
Equipo
Ohio State, Team S1-G2, Whitney Fall 2018 Miembro de Ohio State, Team S1-G2, Whitney Fall 2018
OSU-WHITNEY-F18S1G2
2 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 342
