Saltar al contenido principal
Asus Transformer Book T100TAF Motherboard Replacement
Qué necesitas
  1. Asus Transformer Book T100TAF Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Detach the screen from the keyboard using the silver button and pulling the screen in the upwards direction.
  2. Asus Transformer Book T100TAF Motherboard Replacement: paso 2, imagen 1 de 1
    • Pry the plastic backing off of the tablet using the plastic spudger, releasing all interior clips.
  3. Asus Transformer Book T100TAF Motherboard Replacement: paso 3, imagen 1 de 1
    • Unscrew all the silver screws from the motherboard
    • 3.0 mm (3) silver phillips head
  4. Asus Transformer Book T100TAF Motherboard Replacement: paso 4, imagen 1 de 2 Asus Transformer Book T100TAF Motherboard Replacement: paso 4, imagen 2 de 2
    • Unscrew all the black screws from the motherboard with a PH00 screwdriver
    • 4.5 mm (4) black phillips head
    • 4.5 mm (2) black phillips head
  5. Asus Transformer Book T100TAF Motherboard Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    $3.99
    • Detach the battery cable by steadily pulling it away from the motherboard with angled tweezers.
  6. Asus Transformer Book T100TAF Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently pry the orange ribbon cable that is near the battery cable upwards with tweezers.
  7. Asus Transformer Book T100TAF Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the black strip along the top edge, releasing the two sets of connections.
    • Adhesive may hold this strip to the motherboard.
  8. Asus Transformer Book T100TAF Motherboard Replacement: paso 8, imagen 1 de 1
    • Use tweezers to detach the black and red twisted pair cable from its connection to the motherboard.
  9. Asus Transformer Book T100TAF Motherboard Replacement: paso 9, imagen 1 de 2 Asus Transformer Book T100TAF Motherboard Replacement: paso 9, imagen 2 de 2
    • Detach the two thin black wires by grabbing them with tweezers.
  10. Asus Transformer Book T100TAF Motherboard Replacement: paso 10, imagen 1 de 1
    • With tweezers, gently flip the white clip up that is holding the white ribbon cable down. Pull the base of the white ribbon cable away from the motherboard with tweezers.
  11. Asus Transformer Book T100TAF Motherboard Replacement: paso 11, imagen 1 de 1
    • Disconnect the bottom orange ribbon cable with tweezers by pulling it away from the edge of the device.
  12. Asus Transformer Book T100TAF Motherboard Replacement: paso 12, imagen 1 de 1
    • Verify that cables are no longer attached to the motherboard.
  13. Asus Transformer Book T100TAF Motherboard Replacement: paso 13, imagen 1 de 2 Asus Transformer Book T100TAF Motherboard Replacement: paso 13, imagen 2 de 2
    • Grab the motherboard with two hands, and gently lift it out of the device.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team 4-3, Passmore Fall 2016 Miembro de USF Tampa, Team 4-3, Passmore Fall 2016
USFT-PASSMORE-F16S4G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 2,941
