Saltar al contenido principal
Asus TUF Gaming FX705G M.2 SSD Replacement
Qué necesitas
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: paso 1, imagen 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: paso 2, imagen 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement: paso 2, imagen 2 de 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: paso 3, imagen 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: paso 4, imagen 1 de 2 Asus TUF Gaming FX705G M.2 SSD Replacement: paso 4, imagen 2 de 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: paso 5, imagen 1 de 1
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: paso 6, imagen 1 de 1
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 43
Todo El Tiempo: 4,486
