Saltar al contenido principal
Asus TUF Gaming FX705G Fan Replacement
Qué necesitas
  1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: paso 1, imagen 1 de 2 Asus TUF Gaming FX705G Fan Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Fan Replacement: paso 2, imagen 1 de 2 Asus TUF Gaming FX705G Fan Replacement: paso 2, imagen 2 de 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Fan Replacement, Battery: paso 3, imagen 1 de 2 Asus TUF Gaming FX705G Fan Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Fan Replacement: paso 4, imagen 1 de 2 Asus TUF Gaming FX705G Fan Replacement: paso 4, imagen 2 de 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Fan Replacement, Fan: paso 5, imagen 1 de 2 Asus TUF Gaming FX705G Fan Replacement, Fan: paso 5, imagen 2 de 2
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Fan Replacement: paso 6, imagen 1 de 3 Asus TUF Gaming FX705G Fan Replacement: paso 6, imagen 2 de 3 Asus TUF Gaming FX705G Fan Replacement: paso 6, imagen 3 de 3
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Fan Replacement: paso 7, imagen 1 de 3 Asus TUF Gaming FX705G Fan Replacement: paso 7, imagen 2 de 3 Asus TUF Gaming FX705G Fan Replacement: paso 7, imagen 3 de 3
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
Conclusión
15 personas más completaron esta guía.
3 comentarios
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
1857classic - Contestar
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
Christopher Hall - Contestar
This was very helpful. Thank you
Sue Olmos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 25
Ultimos 30 días: 134
Todo El Tiempo: 15,451
