Saltar al contenido principal
Asus TF300T Tablet Front Facing Camera Replacement
Qué necesitas
  1. Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: paso 1, imagen 1 de 2 Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: paso 1, imagen 2 de 2
    • Disconnect the dock and make sure the power is turned off.
    • Use plastic opening tool to pry screen up and remove the main tablet body from outer rim casing.
    • Be gentle with the plastic opening tool near charging port. The thinner plastic may break easily.
  2. Asus TF300T Tablet Front Facing Camera Replacement: paso 2, imagen 1 de 3 Asus TF300T Tablet Front Facing Camera Replacement: paso 2, imagen 2 de 3 Asus TF300T Tablet Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use plastic tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Front Facing Camera Replacement: paso 3, imagen 1 de 3 Asus TF300T Tablet Front Facing Camera Replacement: paso 3, imagen 2 de 3 Asus TF300T Tablet Front Facing Camera Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use a Phillips #00 Screwdriver to remove the six 3mm screws that connect the upper part of the motherboard.
    • Use tweezers to remove red connecting wires. Remove the motherboard by lifting it upward.
  4. Asus TF300T Tablet Front Facing Camera Replacement: paso 4, imagen 1 de 1
    • Use tweezers to pull out the gold flap connected to the front camera.
    • Pull the disconnected gold flap to take out the camera.
Conclusión
Emma Sloan
Miembro Desde 05/17/17
101 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G2, Wilson Summer 2017 Miembro de IUPUI, Team S2-G2, Wilson Summer 2017
IUPUI-WILSON-SU17S2G2
Miembros de 3
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 328
