Saltar al contenido principal
Asus Rog GL55VW-DH71 Disassembly
Qué necesitas
  1. Asus Rog GL55VW-DH71 Disassembly, Battery: paso 1, imagen 1 de 3 Asus Rog GL55VW-DH71 Disassembly, Battery: paso 1, imagen 2 de 3 Asus Rog GL55VW-DH71 Disassembly, Battery: paso 1, imagen 3 de 3
    • Flip the laptop over so the backside is facing upwards.
    • Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
  2. Asus Rog GL55VW-DH71 Disassembly, Keyboard: paso 2, imagen 1 de 3 Asus Rog GL55VW-DH71 Disassembly, Keyboard: paso 2, imagen 2 de 3 Asus Rog GL55VW-DH71 Disassembly, Keyboard: paso 2, imagen 3 de 3
    • Remove the nine 15.4mm Phillips #00 screws.
    • Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
    • Remove the hard drive bracket.
  3. Asus Rog GL55VW-DH71 Disassembly: paso 3, imagen 1 de 2 Asus Rog GL55VW-DH71 Disassembly: paso 3, imagen 2 de 2
    • Flip laptop over and open the screen.
    • Wedge some plastic opening tools between the keyboard and case.
    • Work your way around with the plastic opening tools until the keyboard is separate from the case.
    • Do not try to lift the keyboard straight off at this time. There are some ribbon cables that attach the motherboard to the keyboard that need to be removed first.
  4. Asus Rog GL55VW-DH71 Disassembly: paso 4, imagen 1 de 3 Asus Rog GL55VW-DH71 Disassembly: paso 4, imagen 2 de 3 Asus Rog GL55VW-DH71 Disassembly: paso 4, imagen 3 de 3
    • Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
    • Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
  5. Asus Rog GL55VW-DH71 Disassembly, Asus Rog GL55VW-DH71 Disassembly: paso 5, imagen 1 de 1
    • Remove the CD/DVD drive by sliding it out of the side of the laptop.
  6. Asus Rog GL55VW-DH71 Disassembly: paso 6, imagen 1 de 3 Asus Rog GL55VW-DH71 Disassembly: paso 6, imagen 2 de 3 Asus Rog GL55VW-DH71 Disassembly: paso 6, imagen 3 de 3
    • Remove the three 6.5mm Phillips #00 screws from the fan.
    • Disconnect the fan power cable from the motherboard.
    • Remove the fan.
  7. Asus Rog GL55VW-DH71 Disassembly: paso 7, imagen 1 de 3 Asus Rog GL55VW-DH71 Disassembly: paso 7, imagen 2 de 3 Asus Rog GL55VW-DH71 Disassembly: paso 7, imagen 3 de 3
    • Gently remove the ribbon cables and wireless chip. A plastic prying tool will help in this removal.
    • Remove the power cable for the motherboard.
    • Remove the power cable for the speaker.
  8. Asus Rog GL55VW-DH71 Disassembly: paso 8, imagen 1 de 1
    • Ensuring no missed connections or screws, remove the motherboard from the assembly.
Conclusión
6 personas más completaron esta guía.
Addison Thomas
Miembro Desde 02/14/18
1,232 Reputación
8 Guías creadas
Equipo
USF Tampa, Team S1-G2, Nance Spring 2018 Miembro de USF Tampa, Team S1-G2, Nance Spring 2018
USFT-NANCE-S18S1G2
4 Miembros
8 Guías creadas
Un comentario
How to assemble it again? I don't have much experience and will do it for the first time watching your guide. Thank you!!
Yogesh Patil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 50
Todo El Tiempo: 8,209
