Saltar al contenido principal
Asus ROG Zephyrus S (GX531GS-AH76) Upgrades
Qué necesitas
  1. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Prepare Laptop, Tools and New Components: paso 1, imagen 1 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Prepare Laptop, Tools and New Components: paso 1, imagen 2 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Prepare Laptop, Tools and New Components: paso 1, imagen 3 de 3
    • First, unplug anything that is plugged into the ports of the laptop.
    • Next, Shut Down the laptop completely.
    • Make sure you have the tools you need and make sure you have space to work unobstructed.
  2. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Fan Cover: paso 2, imagen 1 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Fan Cover: paso 2, imagen 2 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Fan Cover: paso 2, imagen 3 de 3
    • Next, flip your laptop upside down and remove the 2 sets of screws highlighted in yellow with your Phillips 0 screwdriver, There are 2 sets of 2.
    • Then open the laptop to roughly 45 degrees and place it on its side as shown. From this position you can wiggle the dust cover off.
    • If you are having trouble then open or close the lid a little further. When you have it in the right position it will require no force, it will slide right off.
  3. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Screws, Screws, Screws: paso 3, imagen 1 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Screws, Screws, Screws: paso 3, imagen 2 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Screws, Screws, Screws: paso 3, imagen 3 de 3
    • Now remove the 13 Philips 0 screws marked in yellow .
    • Make sure you only remove the screws that are circled. There are a few that are not circled and do not need to be removed.
    • Next remove the 6 T5 Torx screws circled in orange
    • flip the laptop over and you are going to gently pry the hinge cover off.
    • Once loose, carefully disconnect the 2 cables marked in yellow that are attaching it to the motherboard.
  4. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Keyboard Removal: paso 4, imagen 1 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Keyboard Removal: paso 4, imagen 2 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Keyboard Removal: paso 4, imagen 3 de 3
    • It should now look like this.
    • Now flip open the lid. Use your opening tool to pry apart the seam shown.
    • Work your way around the seam until it is loose all the way around but do not lift the keyboard off yet.
  5. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Keyboard: paso 5, imagen 1 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Keyboard: paso 5, imagen 2 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Keyboard: paso 5, imagen 3 de 3
    • Very carefully lift the keyboard from the side closest to the screen while not pulling the attaching cables too tight
    • .Once you have space to reach in, then you can unclip the 4 cables from their connectors marked with yellow boxes here and then set the entire keyboard assembly to the side.
    • Your laptop should look like this now.
    • The yellow box on the left is around the SSD and the one on the right is the RAM.
  6. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove the Old RAM: paso 6, imagen 1 de 2 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove the Old RAM: paso 6, imagen 2 de 2
    • Push the retaining clip on each side of the RAM module to the left and right away from it. This will release the RAM and it will pop up at a 45 degree angle. You can now slide it out.
    • Next slide your new stick of RAM in and push it down until it clicks.
  7. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Old SSD: paso 7, imagen 1 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Old SSD: paso 7, imagen 2 de 3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Old SSD: paso 7, imagen 3 de 3
    • Next, fold the ribbon out of the way that is covering the SSD and remove the SSD retaining screw.
    • Now gently pry up on that same end until it lifts off the sticky thermal pad underneath. It doesn't take much. Once you are clear of the pad you can pull the SSD out of it's M.2 socket.
    • Now install your new SSD and secure it with the retaining screw.
  8. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Cleaning then Re-assembly: paso 8, imagen 1 de 2 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Cleaning then Re-assembly: paso 8, imagen 2 de 2
    • While it is apart, clean your fans from above and underneath. Get all the dust out you can. Once done you can start putting it back together in reverse order.
Conclusión
28 personas más completaron esta guía.
TooMuchSauce
Miembro Desde 12/30/18
1,533 Reputación
1 Guía escrita
34 comentarios
What about the software on the old drive, operating system and all? How to clone the m.2 drive?
Steve Del Hoyo - Contestar
I used an external m.2 enclosure like the one I’ll link below and the free maxium reflect software to clone my existing drive. Once the swap is completed you can use the enclosure with your old ssd as an external drive if you want. https://www.amazon.com/Sabrent-NGFF-Alum...
TooMuchSauce - Contestar
The $12 or $45 one? There are two on that Amazon link
willshahbazian -
The product on that link has changed but I would use the $50 one depending on the SSD you buy.
TooMuchSauce -
Thank you! It worked for me
willshahbazian -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 34
Ultimos 30 días: 145
Todo El Tiempo: 33,473
