Saltar al contenido principal
Asus ROG Zephyrus M15 GU502L Touchpad Replacement
Qué necesitas
  1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: paso 1, imagen 1 de 2 Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: paso 1, imagen 2 de 2
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: paso 2, imagen 1 de 2 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: paso 3, imagen 1 de 1
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: paso 4, imagen 1 de 2 Asus ROG Zephyrus M15 GU502L Touchpad Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the computer.
  6. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Touchpad: paso 6, imagen 1 de 1
    • Remove the 3mm screws that secure the touchpad using a Phillips #0 screwdriver.
  7. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: paso 7, imagen 1 de 1
    • Remove the touch pad from the casing.
    • Be cautious picking up the touch pad as it is light.
Conclusión
Yahir Donis
Miembro Desde 09/07/23
339 Reputación
2 Guías creadas
Equipo
Gateway, Team 69-69, Gonzalez Fall 2023 Miembro de Gateway, Team 69-69, Gonzalez Fall 2023
GCC-GONZALEZ-F23S69G69
Miembros de 4
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 36
Todo El Tiempo: 307
