Introducción
The motherboard is connected to everything within the computer, so if it sustains damage, likely the machine will not function smoothly.
If you motherboard has been broken or exposed to water, this guide will show you how to remove it.
Qué necesitas
Remove the 1.6 mm and 9 mm screws from the back panel using the Phillips #1 screwdriver.
Casi Terminas!
Conclusión
