Saltar al contenido principal
Asus ROG Strix GL702VS Trackpad Replacement
Qué necesitas
  1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Trackpad Replacement: paso 2, imagen 1 de 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Trackpad Replacement: paso 3, imagen 1 de 2 Asus ROG Strix GL702VS Trackpad Replacement: paso 3, imagen 2 de 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Trackpad Replacement: paso 4, imagen 1 de 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: paso 5, imagen 1 de 3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: paso 5, imagen 2 de 3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: paso 5, imagen 3 de 3
    • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
    • Slide the ribbon cables out of the connectors on the motherboard.
  6. Asus ROG Strix GL702VS Trackpad Replacement: paso 6, imagen 1 de 2 Asus ROG Strix GL702VS Trackpad Replacement: paso 6, imagen 2 de 2
    • Remove the covering foil holding the trackpad into place.
    • Completely peel the foil back to ensure it does not interfere with the following processes.
  7. Asus ROG Strix GL702VS Trackpad Replacement: paso 7, imagen 1 de 2 Asus ROG Strix GL702VS Trackpad Replacement: paso 7, imagen 2 de 2
    • Lift up speaker cable that is laying overtop using a pair of tweezers.
    • Do not to overextend the wire since you may accidently pull the wire out.
  8. Asus ROG Strix GL702VS Trackpad Replacement: paso 8, imagen 1 de 3 Asus ROG Strix GL702VS Trackpad Replacement: paso 8, imagen 2 de 3 Asus ROG Strix GL702VS Trackpad Replacement: paso 8, imagen 3 de 3
    • Remove the three 4mm JIS #0 screws that are securing the trackpad.
  9. Asus ROG Strix GL702VS Trackpad Replacement: paso 9, imagen 1 de 2 Asus ROG Strix GL702VS Trackpad Replacement: paso 9, imagen 2 de 2
    • Once freed, slide the trackpad backwards towards the center of laptop.
    • This may require some jiggling. Lifting the laptop off your working surface may help.
    • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 802
