Saltar al contenido principal
Asus ROG Strix GL702VS Speaker Replacement
Qué necesitas
  1. Asus ROG Strix GL702VS Speaker Replacement, Back Cover: paso 1, imagen 1 de 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Speaker Replacement: paso 3, imagen 1 de 2 Asus ROG Strix GL702VS Speaker Replacement: paso 3, imagen 2 de 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Speaker Replacement: paso 4, imagen 1 de 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Speaker Replacement, Speaker: paso 5, imagen 1 de 3 Asus ROG Strix GL702VS Speaker Replacement, Speaker: paso 5, imagen 2 de 3 Asus ROG Strix GL702VS Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Disconnect the two sets of speaker connectors using a pair of tweezers.
  6. Asus ROG Strix GL702VS Speaker Replacement: paso 6, imagen 1 de 3 Asus ROG Strix GL702VS Speaker Replacement: paso 6, imagen 2 de 3 Asus ROG Strix GL702VS Speaker Replacement: paso 6, imagen 3 de 3
    • Gently remove the speakers by lifting up.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 1,076
