Saltar al contenido principal
Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement
Qué necesitas
  1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 2 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: paso 2, imagen 1 de 3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: paso 2, imagen 2 de 3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: paso 2, imagen 3 de 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  4. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
Conclusión
8 personas más completaron esta guía.
Zach Langer
Miembro Desde 04/10/17
676 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S13-G2, Forte Spring 2017 Miembro de Cal Poly, Team S13-G2, Forte Spring 2017
CPSU-FORTE-S17S13G2
Miembros de 4
4 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 33
Todo El Tiempo: 7,604
