Saltar al contenido principal
Asus ROG Strix GL702VM-BHI7N09 Fan Replacement
Qué necesitas
  1. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Back Panel: paso 1, imagen 1 de 2 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 2, imagen 1 de 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 2, imagen 2 de 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 2, imagen 3 de 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Fan: paso 3, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
  4. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 4, imagen 1 de 1
    • The smaller black fan must be removed before the larger gray fan on the right can be taken out.
    • To remove the black fan, pull gently on the connecting cables outlined.
  5. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 5, imagen 1 de 1
    • Unplug the white connector by gently pulling the cables.
    • Lift off the gray fan.
  6. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the two indicated 4 mm screws from the other gray fan.
  7. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 7, imagen 1 de 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 7, imagen 2 de 3 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: paso 7, imagen 3 de 3
    • Unplug the white connector by gently pulling it towards the center of the computer.
    • Lift the fan out of the body of the laptop to remove it.
Conclusión
9 personas más completaron esta guía.
Zach Langer
Miembro Desde 04/10/17
676 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S13-G2, Forte Spring 2017 Miembro de Cal Poly, Team S13-G2, Forte Spring 2017
CPSU-FORTE-S17S13G2
Miembros de 4
4 Guías creadas
8 comentarios
one of my laptop fans doesn’t work. where can i get a new one? I didn’t see any new fans for this model of laptop for sale anywhere
Mohammadreza Safaee - Contestar
محمد رضا جان شما میتونید فن رو باز کنید و مشابهش رو از بازار تهیه کنید
Alireza Soheili -
I was wondering the same. I couldn’t find fans anywhere and after contacting ASUS about them they seemed less than interested in selling me the fans so that I could fix my laptop myself.
Chris Moody - Contestar
Can’t seem to find the fan anywhere
jon_souza - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 33
Todo El Tiempo: 9,190
