Saltar al contenido principal
Asus ROG Strix GL702VM-BHI7N09 Battery Replacement
Qué necesitas
  1. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: paso 2, imagen 1 de 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: paso 2, imagen 2 de 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: paso 2, imagen 3 de 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: paso 4, imagen 1 de 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: paso 4, imagen 2 de 3 Asus ROG Strix GL702VM-BHI7N09 Battery Replacement: paso 4, imagen 3 de 3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
Conclusión
6 personas más completaron esta guía.
Un comentario
Cheers mate! Worked like a %#*@. Built lots of PCs in my time but this is the first time I’ve taken a laptop apart. I should mention: there are 4 screws holding the battery in rather than the 1 you mention in this guide.
Collin MacQuarrie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 76
Todo El Tiempo: 10,036
