Saltar al contenido principal
Asus ROG Strix GL553VD Battery Replacement
Qué necesitas
  1. Asus ROG Strix GL553VD Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus ROG Strix GL553VD Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the ten 4 mm T5 Torx screws from the bottom cover.
  2. Asus ROG Strix GL553VD Battery Replacement: paso 2, imagen 1 de 2 Asus ROG Strix GL553VD Battery Replacement: paso 2, imagen 2 de 2
    • Open the flap in the middle to reveal the 11th screw and remove it using the same T5 Torx driver.
  3. Asus ROG Strix GL553VD Battery Replacement: paso 3, imagen 1 de 3 Asus ROG Strix GL553VD Battery Replacement: paso 3, imagen 2 de 3 Asus ROG Strix GL553VD Battery Replacement: paso 3, imagen 3 de 3
    • Gently lift each corner to remove the cover from the laptop.
    • If you seem to have difficulty removing the cover, you may use a plastic opening tool to pry up one of the corners to get you started.
  4. Asus ROG Strix GL553VD Battery Replacement: paso 4, imagen 1 de 3 Asus ROG Strix GL553VD Battery Replacement: paso 4, imagen 2 de 3 Asus ROG Strix GL553VD Battery Replacement: paso 4, imagen 3 de 3
    • Gently pull the white battery connector out towards the battery.
  5. Asus ROG Strix GL553VD Battery Replacement: paso 5, imagen 1 de 1
    • Carefully lift the battery out from the case to remove it.
    • The battery will come off easily as the screws are already removed.
Conclusión
3 personas más completaron esta guía.
Mahmoud Mehdi
Miembro Desde 09/20/20
223 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 95
Todo El Tiempo: 3,303
