Saltar al contenido principal
Asus ROG STRIX GL502V Motherboard Replacement
Qué necesitas
  1. Asus ROG STRIX GL502V Motherboard Replacement, Asus ROG STRIX GL502V Lower Case: paso 1, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement, Asus ROG STRIX GL502V Lower Case: paso 1, imagen 2 de 2
    • Remove 10 screws.
    • Note: front screws (blue) are 10mm long, central and rear (brown) are 12mm.
  2. Asus ROG STRIX GL502V Motherboard Replacement: paso 2, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement: paso 2, imagen 2 de 2
    • With opening tool or pick go around the case starting from back corner.
  3. Asus ROG STRIX GL502V Motherboard Replacement: paso 3, imagen 1 de 1
    • Lift cover and now you have access to most of the components.
  4. Asus ROG STRIX GL502V Motherboard Replacement, Battery: paso 4, imagen 1 de 1
    • Disconnect battery connect by pulling it up.
  5. Asus ROG STRIX GL502V Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove 4 screws
  6. Asus ROG STRIX GL502V Motherboard Replacement: paso 6, imagen 1 de 1
    • Lift battery up and out.
  7. Asus ROG STRIX GL502V Motherboard Replacement, Remove memory module: paso 7, imagen 1 de 1
    • Pull spring locks out.
    • Lift module up and out of the connector.
  8. Asus ROG STRIX GL502V Motherboard Replacement, M.2 SSD: paso 8, imagen 1 de 1
    • remove screw.
    • pull up and right from the connector.
  9. Asus ROG STRIX GL502V Motherboard Replacement, Connectors: paso 9, imagen 1 de 1
    • Antenna (orange)
    • Speakers (yellow)
    • Power and miscellaneous LED (blue)
    • Keyboard (green)
    • Display (pink)
  10. Asus ROG STRIX GL502V Motherboard Replacement, Remove speaker connector: paso 10, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement, Remove speaker connector: paso 10, imagen 2 de 2
    • Remove speaker connector by pulling it out.
  11. Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: paso 11, imagen 1 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: paso 11, imagen 2 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove keyboard connector: paso 11, imagen 3 de 3
    • Lift locking mechanism up
    • Pull ribbon cable from connector
  12. Asus ROG STRIX GL502V Motherboard Replacement, Remove miscellanious connectors: paso 12, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement, Remove miscellanious connectors: paso 12, imagen 2 de 2
    • Lift locking tab on each connector (3x)
    • Pull each ribbon cable out
  13. Asus ROG STRIX GL502V Motherboard Replacement, Display cable: paso 13, imagen 1 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Display cable: paso 13, imagen 2 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Display cable: paso 13, imagen 3 de 3
    • Remove screw holding display cable
    • Remove plastic shield over display cable
    • Pull cable out of the clip
  14. Asus ROG STRIX GL502V Motherboard Replacement, Display connector: paso 14, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement, Display connector: paso 14, imagen 2 de 2
    • Pull display connector straight up by the pull strap
  15. Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: paso 15, imagen 1 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: paso 15, imagen 2 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector: paso 15, imagen 3 de 3
    • Carefully holding by metal part pull connector up.
    • Repeat for second connector.
  16. Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector cable: paso 16, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement, Antenna connector cable: paso 16, imagen 2 de 2
    • Move connector out of the guide.
  17. Asus ROG STRIX GL502V Motherboard Replacement, Hinges screws: paso 17, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement, Hinges screws: paso 17, imagen 2 de 2
    • Remove remaining hinges screws (5)
    • Note: one screw was holding display cable.
  18. Asus ROG STRIX GL502V Motherboard Replacement, Lift Hinghes: paso 18, imagen 1 de 2 Asus ROG STRIX GL502V Motherboard Replacement, Lift Hinghes: paso 18, imagen 2 de 2
    • Lift left hinge up.
    • Lift right hinge up.
  19. Asus ROG STRIX GL502V Motherboard Replacement, Motherboard screws: paso 19, imagen 1 de 1
    • Remove two side motherboard screws (yellow marks)
    • Remove 4 center screws (green marks)
    • Note: side screws silver and slighter longer.
  20. Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: paso 20, imagen 1 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: paso 20, imagen 2 de 3 Asus ROG STRIX GL502V Motherboard Replacement, Remove motherboard: paso 20, imagen 3 de 3
    • NOTE: Headset connector is holding in the case.
    • Lift motherboard from HDMI connector side and pull towards it.
  21. Asus ROG STRIX GL502V Motherboard Replacement, Remove fans, heat sink and radio module: paso 21, imagen 1 de 1
    • Remove radio module screw (red) and pull it out of connector.
    • Disconnect fans connectors and remove 6x screws. Pull fans out.
    • Remove 8 screws from heat sink and remove it.
    • Note: heat sink use thermal paste on CPU and GPU - you will need to clean and use new before putting it together.
Conclusión
Sergei
Miembro Desde 09/10/12
568 Reputación
5 Guías creadas
Un comentario
Hello I am interested motherboard, how much it's the price ?
Leonard Cristian - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 142
