Saltar al contenido principal
Asus ROG GL551J Screen Replacement
Qué necesitas
  1. Asus ROG GL551J Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: paso 2, imagen 1 de 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: paso 3, imagen 1 de 1
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: paso 4, imagen 1 de 2 Asus ROG GL551J Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: paso 5, imagen 1 de 2 Asus ROG GL551J Screen Replacement: paso 5, imagen 2 de 2
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: paso 6, imagen 1 de 2 Asus ROG GL551J Screen Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: paso 7, imagen 1 de 1
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: paso 8, imagen 1 de 2 Asus ROG GL551J Screen Replacement: paso 8, imagen 2 de 2
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
Conclusión
Una persona más ha completado esta guía.
Thien Vu
Miembro Desde 02/15/17
412 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-4, Lacy Spring 2017 Miembro de USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
Miembros de 4
5 Guías creadas
Un comentario
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 3,193
