Saltar al contenido principal
Asus ROG GL551J Hard Drive Replacement
Qué necesitas
  1. Asus ROG GL551J Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Hard Drive Replacement: paso 2, imagen 1 de 1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Hard Drive Replacement: paso 3, imagen 1 de 1
    • Pull the battery out.
  4. Asus ROG GL551J Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Asus ROG GL551J Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
    • Slide the panel out and lift up to remove.
  5. Asus ROG GL551J Hard Drive Replacement: paso 5, imagen 1 de 2 Asus ROG GL551J Hard Drive Replacement: paso 5, imagen 2 de 2
    • The hard drive is the metal rectangle with the two soft padding bars attached to it.
    • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
  6. Asus ROG GL551J Hard Drive Replacement: paso 6, imagen 1 de 2 Asus ROG GL551J Hard Drive Replacement: paso 6, imagen 2 de 2
    • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
    • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
    • Once the hard drive detaches from the connector, lift the hard drive up and out.
Conclusión
7 personas más completaron esta guía.
Thien Vu
Miembro Desde 02/15/17
412 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-4, Lacy Spring 2017 Miembro de USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 18
Todo El Tiempo: 4,470
