Introducción
This guide will explain the step-by-step process for replacing your RAM. Replacing the RAM could be necessary if you're laptop is not turning on.
Qué necesitas
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Lift away the metal housings from each side of the laptop.
First locate the RAM.
Then pull the tabs located on the left and right of the RAM outwards to release the RAM.
You can now remove the RAM and replace it.
Una persona más ha completado esta guía.
