Saltar al contenido principal
Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement
Qué necesitas
  1. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: paso 1, imagen 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: paso 1, imagen 2 de 2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 2, imagen 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 2, imagen 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 2, imagen 3 de 3
    • Use the standard spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 3, imagen 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 3, imagen 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 3, imagen 3 de 3
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 4, imagen 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 4, imagen 2 de 2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 5, imagen 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 5, imagen 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 5, imagen 3 de 3
    • Remove the screws holding the hard drives in place using a Phillips 1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
  6. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 6, imagen 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  7. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 7, imagen 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 7, imagen 2 de 2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 8, imagen 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 8, imagen 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 8, imagen 3 de 3
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 9, imagen 1 de 1
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  10. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 10, imagen 1 de 1
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  11. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 11, imagen 1 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 11, imagen 2 de 3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 11, imagen 3 de 3
    • Use a metal spudger to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 12, imagen 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 12, imagen 2 de 2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 13, imagen 1 de 2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: paso 13, imagen 2 de 2
    • Use a pair of tweezers to undo each of the two ribbon connectors.
    • The Left and right button is now completely disconnected from the laptop and you can remove it.
Conclusión
3 personas más completaron esta guía.
Equipo
IUPUI, Team S8-G8, Wilson Spring 2019 Miembro de IUPUI, Team S8-G8, Wilson Spring 2019
IUPUI-WILSON-S19S8G8
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 22
Todo El Tiempo: 1,119
