Saltar al contenido principal
Asus ROG G751JL-BSI7T28 SD Card Reader Replacement
Qué necesitas
  1. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement, Back Panel: paso 1, imagen 1 de 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 2, imagen 1 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 2, imagen 2 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 2, imagen 3 de 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement, Display Assembly: paso 3, imagen 1 de 2 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement, Display Assembly: paso 3, imagen 2 de 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 4, imagen 1 de 2 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 4, imagen 2 de 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 5, imagen 1 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 5, imagen 2 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 5, imagen 3 de 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 6, imagen 1 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 6, imagen 2 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 6, imagen 3 de 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 7, imagen 1 de 2 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 7, imagen 2 de 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement, Keyboard Assembly: paso 8, imagen 1 de 2 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement, Keyboard Assembly: paso 8, imagen 2 de 2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement, SD Card Reader: paso 9, imagen 1 de 2 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement, SD Card Reader: paso 9, imagen 2 de 2
    • Flip the SD card reader's retaining arm up.
    • Remove the SD card reader's power/data ribbon cable.
  10. Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 10, imagen 1 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 10, imagen 2 de 3 Asus ROG G751JL-BSI7T28 SD Card Reader Replacement: paso 10, imagen 3 de 3
    • Remove three 3mm Phillips #0 screws from the SD card reader.
    • Remove the SD card reader.
Conclusión
Dylan Michael Leonard
Miembro Desde 11/05/19
423 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 214
