Qué necesitas
Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
Remove the four 2.4 mm screws securing the left hard drive with a Phillips screwdriver.
Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
Una persona más ha completado esta guía.
1Guía Comentario
Dose the Asus ROG G751JL have any m.2 port in there anywhere? And what is the maximum capacity of SSD use in the Asus ROG G751JL?
