Saltar al contenido principal
Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement
Qué necesitas
  1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: paso 1, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: paso 1, imagen 2 de 2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 2, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 2, imagen 2 de 2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 3, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 3, imagen 2 de 2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 4, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 4, imagen 2 de 2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 5, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 5, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 5, imagen 3 de 3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: paso 6, imagen 1 de 1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 391
