Saltar al contenido principal
Asus ROG G750JM-BSI7N23 Motherboard Replacement
Qué necesitas
  1. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Soundbar/speaker: paso 1, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Soundbar/speaker: paso 1, imagen 2 de 2
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 2, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 3, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 3, imagen 2 de 2
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 4, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 5, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 5, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 5, imagen 3 de 3
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 6, imagen 1 de 1
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
  7. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Back Plate: paso 7, imagen 1 de 1
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  8. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 8, imagen 1 de 1
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  9. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 9, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 9, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 9, imagen 3 de 3
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  10. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: paso 10, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: paso 10, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Keyboard: paso 10, imagen 3 de 3
    • Remove the six 8mm Phillips #2 screws to remove the display.
    • Remove the two 4mm Phillips #2 screws.
  11. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 11, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 11, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 11, imagen 3 de 3
    • Remove the four rubber tabs circled in green on the bottom of the device.
    • Remove the five 4mm #2 Phillips screws.
    • Remove the two 8mm #2 Phillips screws.
    • Remove the two 1cm #2 Phillips screws.
  12. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 12, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 12, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 12, imagen 3 de 3
    • Pry around the keyboard on the top topside as shown to remove it from shell.
  13. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 13, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 13, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 13, imagen 3 de 3
    • Remove the four connectors using your pry tool.
    • The keyboard will now be separated from the main computer.
  14. Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: paso 14, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: paso 14, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement, Motherboard: paso 14, imagen 3 de 3
    • First, remove the two 7mm #2 Phillips screws circled in red to fold the silver plate over.
    • Remove all the connectors shown in the orange squares. You may need to use your plastic opening tool for the smaller ones.
  15. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 15, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 15, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 15, imagen 3 de 3
    • Remove the three #2 Phillips screws from the small wireless card located in the top left.
  16. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 16, imagen 1 de 2 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 16, imagen 2 de 2
    • Remove the three #2 Phillips screws from the small power button card in the top right.
  17. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 17, imagen 1 de 1
    • Remove the two #2 Phillips screws for the audio card located in the bottom right.
  18. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 18, imagen 1 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 18, imagen 2 de 3 Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 18, imagen 3 de 3
    • Remove all 8mm #2 Phillips screws .
    • Remove all 2mm #2 Phillips screws.
    • Remove all 3mm #2 Phillips screws.
    • Remove all 7mm #2 Phillips screws.
    • Remove all 4mm #2 Phillips screws.
  19. Asus ROG G750JM-BSI7N23 Motherboard Replacement: paso 19, imagen 1 de 1
    • When all the screws are removed, pry up on the edges of the circuit board. You may need your plastic opening tool to access the edges.
Conclusión
3 personas más completaron esta guía.
Un comentario
Outstanding and that's from someone who has been turning screws on computers from the 8086 chip to and IBM 4381 then wrote a few books on the subject. This is the best tutorial I've ever came across, now do the G752. It's my next project after I find a motherboard.
Bill - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 36
Todo El Tiempo: 1,950
