Introducción
Use this guide if your computer is not responding even after you have replaced the battery and power components.
Qué necesitas
Using a plastic opening tool, remove the two rubber tabs circled in red.
With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
Remove the six 8mm Phillips #2 screws to remove the display.
Remove the two 4mm Phillips #2 screws.
First, remove the two 7mm #2 Phillips screws circled in red to fold the silver plate over.
Remove all the connectors shown in the orange squares. You may need to use your plastic opening tool for the smaller ones.
3 personas más completaron esta guía.
