Saltar al contenido principal
Asus ROG G750JM-BS17N23 Hard Drive Replacement
Qué necesitas
  1. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Back Plate: paso 1, imagen 1 de 1
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  2. Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  3. Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 3, imagen 1 de 3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 3, imagen 2 de 3 Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 3, imagen 3 de 3
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  4. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • To access the hard drive, remove the back plate.
  5. Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 5, imagen 1 de 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Remove the three 4mm Phillips #2 screws.
  6. Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 6, imagen 1 de 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
  7. Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 7, imagen 1 de 2 Asus ROG G750JM-BS17N23 Hard Drive Replacement: paso 7, imagen 2 de 2
    • With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 522
