Saltar al contenido principal
Introducción
To access your hard drive, remove the back plate as shown in these steps.
Partes
No se especificaron partes.
  1. With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Retract the Phillips #2 screw until the cover is loose.
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  4. Pry around the edges of the plate using a plastic opening tool until the plate is removed. Pry around the edges of the plate using a plastic opening tool until the plate is removed. Pry around the edges of the plate using a plastic opening tool until the plate is removed.
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 83
