Saltar al contenido principal
Asus ROG G750JH-DB71 Hard Drive Replacement
Qué necesitas
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: paso 2, imagen 1 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: paso 2, imagen 2 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: paso 4, imagen 1 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: paso 4, imagen 2 de 3 Asus ROG G750JH-DB71 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
Conclusión
Devin Medeiros
Miembro Desde 10/25/22
219 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 5-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G5
Miembros de 4
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 194
