Saltar al contenido principal
Asus ROG G74SX-DH73-3D Battery Replacement
Qué necesitas
  1. Asus ROG G74SX-DH73-3D Battery Replacement, Battery: paso 1, imagen 1 de 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: paso 1, imagen 2 de 3 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: paso 1, imagen 3 de 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
Conclusión
2 comentarios
The note bullet should just be a bullet. Check grammar on the Red bullet.
Joseph McCoy - Contestar
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
Nicholas Ivey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 394
