Saltar al contenido principal
Asus ROG G55VW-DH71 RAM Replacement
Qué necesitas
  1. Asus ROG G55VW-DH71 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Flip the device over so that the bottom of the computer is easily accessible.
    • Using the Phillips size 0 head screwdriver, remove both 3.6mm. screws on the back plate located on the bottom left portion of the back of the laptop.
  2. Asus ROG G55VW-DH71 RAM Replacement: paso 2, imagen 1 de 1
    • Lift up and remove the back plate from the device.
  3. Asus ROG G55VW-DH71 RAM Replacement: paso 3, imagen 1 de 1
    • Gently pry apart the two white clips, that are holding in the RAM cards in, outwards.
  4. Asus ROG G55VW-DH71 RAM Replacement: paso 4, imagen 1 de 1
    • Lift then gently pull out the RAM card.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 686
