Saltar al contenido principal
Asus ROG G55VW-DH71 Hard Drive Replacement
Qué necesitas
  1. Asus ROG G55VW-DH71 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Using the Phillips size 0 head screwdriver, remove the 2 3.6 mm screws on the back plate located on the bottom left portion of the back of the laptop.
  2. Asus ROG G55VW-DH71 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Lift up and remove the back plate that is located in the back, bottom left portion of the laptop.
  3. Asus ROG G55VW-DH71 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Using the Phillips size 0 remove both 4.6 mm screws from the metal tabs.
  4. Asus ROG G55VW-DH71 Hard Drive Replacement: paso 4, imagen 1 de 2 Asus ROG G55VW-DH71 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Grab the plastic tab.
    • Gently pull towards the outer edge of the device.
    • Lift out to fully remove.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 788
