Saltar al contenido principal
Asus ROG G55VW-DH71 Camera Replacement
Qué necesitas
  1. Asus ROG G55VW-DH71 Camera Replacement, Camera: paso 1, imagen 1 de 2 Asus ROG G55VW-DH71 Camera Replacement, Camera: paso 1, imagen 2 de 2
    • Using your iFixit opening tool, separate the frame by gently prying the two seams apart without completely removing the plastic frame piece.
  2. Asus ROG G55VW-DH71 Camera Replacement: paso 2, imagen 1 de 1
    • Once the frame is separated from the screen you will see the camera located in the top middle of the computer.
    • Using your iFixit opening tool, push the camera forward from behind, popping it out.
  3. Asus ROG G55VW-DH71 Camera Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Once the camera is accessible you will see it is connected to the laptop by a small wire that is clipped into the camera.
    • Using tweezers, gently pinch each side of the clipped in attachment that is connected to the camera to separate the computers wire from the old camera.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 424
