Saltar al contenido principal
Asus ROG G53SW-XT1 Optical Drive Replacement
Qué necesitas
  1. Asus ROG G53SW-XT1 Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Optical Drive Replacement: paso 2, imagen 1 de 1
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Optical Drive Replacement: paso 3, imagen 1 de 2 Asus ROG G53SW-XT1 Optical Drive Replacement: paso 3, imagen 2 de 2
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: paso 4, imagen 1 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: paso 4, imagen 2 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: paso 4, imagen 3 de 3
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Optical Drive Replacement: paso 5, imagen 1 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement: paso 5, imagen 2 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement: paso 5, imagen 3 de 3
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: paso 6, imagen 1 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: paso 6, imagen 2 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: paso 6, imagen 3 de 3
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Optical Drive Replacement: paso 7, imagen 1 de 1
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Optical Drive Replacement: paso 8, imagen 1 de 2 Asus ROG G53SW-XT1 Optical Drive Replacement: paso 8, imagen 2 de 2
    • Flip the laptop over and pull off the bottom cover.
  9. Asus ROG G53SW-XT1 Optical Drive Replacement, Optical Drive: paso 9, imagen 1 de 1
    • Remove the single 7mm Phillips #0 screw holding the hard drive in place.
  10. Asus ROG G53SW-XT1 Optical Drive Replacement: paso 10, imagen 1 de 2 Asus ROG G53SW-XT1 Optical Drive Replacement: paso 10, imagen 2 de 2
    • Slide the hard drive out of the casing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 250
