Saltar al contenido principal
Asus ROG FX60VM Hard Drive Replacement
Qué necesitas
  1. Asus ROG FX60VM Hard Drive Replacement, HDD: paso 1, imagen 1 de 2 Asus ROG FX60VM Hard Drive Replacement, HDD: paso 1, imagen 2 de 2
    • Before disassembling the laptop, turn the laptop off and make sure it's unplugged from the power supply.
  2. Asus ROG FX60VM Hard Drive Replacement: paso 2, imagen 1 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 2, imagen 2 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 2, imagen 3 de 3
    • Flip the laptop over so the back case is facing up.
    • Remove the ten 2.5 mm screws from the back case using a Phillips #0 screwdriver.
    • Use a plastic opening tool and picks to pry the back panel off of the device.
  3. Asus ROG FX60VM Hard Drive Replacement: paso 3, imagen 1 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 3, imagen 2 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 3, imagen 3 de 3
    • Put the tip of Halberd spudger under the battery connector and lift it gently to disconnect it from the motherboard.
    • You may need to wiggle the spudger up and down in order to disconnect the battery connector.
  4. Asus ROG FX60VM Hard Drive Replacement: paso 4, imagen 1 de 2 Asus ROG FX60VM Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the four 3.0 mm screws from the HDD case using a Phillips #1 screwdriver.
  5. Asus ROG FX60VM Hard Drive Replacement: paso 5, imagen 1 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 5, imagen 2 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 5, imagen 3 de 3
    • Do not lift the HDD up, as you may damage the connector highlighted in red.
    • Hold the back of the HDD , and slide it out of the port to disconnect it from the motherboard.
  6. Asus ROG FX60VM Hard Drive Replacement: paso 6, imagen 1 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 6, imagen 2 de 3 Asus ROG FX60VM Hard Drive Replacement: paso 6, imagen 3 de 3
    • Remove the two 3.0 mm screws on each side of the HDD mounting bracket using a Phillips #1 screwdriver.
    • Lift the HDD out of the mounting bracket, and install a new HDD or SSD to the mounting bracket.
Conclusión
After install a new HDD or SSD, for better performace, initialize the new disk.
Una persona más ha completado esta guía.
JingZhao Liang
Miembro Desde 06/26/22
163 Reputación
1 Guía escrita
Equipo
Un comentario
Thank you so much JingZhao Liang for the concise and to the point guide. It's easy to follow and I am very impressed that you mentioned how to dispose the e-waste properly in conclusion part.
Tayyaba Riasat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 500
