Introducción
This guide is for the replacement of a broken or faulty CD drive.
Qué necesitas
Flip the laptop over so that the back panel is facing up.
Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
Casi Terminas!
Conclusión
