Saltar al contenido principal
Asus R541UA-RB51 CD Drive Replacement
Qué necesitas
  1. Asus R541UA-RB51 CD Drive Replacement, Keyboard: paso 1, imagen 1 de 3 Asus R541UA-RB51 CD Drive Replacement, Keyboard: paso 1, imagen 2 de 3 Asus R541UA-RB51 CD Drive Replacement, Keyboard: paso 1, imagen 3 de 3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 CD Drive Replacement: paso 2, imagen 1 de 2 Asus R541UA-RB51 CD Drive Replacement: paso 2, imagen 2 de 2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 CD Drive Replacement: paso 3, imagen 1 de 2 Asus R541UA-RB51 CD Drive Replacement: paso 3, imagen 2 de 2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 CD Drive Replacement, CD Drive: paso 4, imagen 1 de 1
    • Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
  5. Asus R541UA-RB51 CD Drive Replacement: paso 5, imagen 1 de 2 Asus R541UA-RB51 CD Drive Replacement: paso 5, imagen 2 de 2
    • Gently slide the CD drive away and pull up to remove it from the computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 307
