Introducción
Is your screen cracked or otherwise damaged? Are unusual visuals popping up seemingly at random? Screen replacement is not as daunting as it may seem. With a metal spudger and a JIS head screwdriver, you can replace your screen in only a few minutes.
Qué necesitas
Using a metal spudger, pick out the stoppers located on the bottom left/right corners of the screen, revealing the screws underneath them.
Unscrew the two 4.25mm screws with the JIS 00 screwdriver.
3 personas más completaron esta guía.
