Saltar al contenido principal
Asus R510CA-OB01 Keyboard and Mousepad Replacement
Qué necesitas
  1. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: paso 1, imagen 1 de 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: paso 1, imagen 2 de 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the two switches that lock the battery.
    • Then, push the right switch outward to unlock it.
  2. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 2, imagen 1 de 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 2, imagen 2 de 2
    • Push the left switch outward and push the battery upward at the same time.
  3. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 3, imagen 1 de 1
    • Use a Li-ion battery as a replacement for your battery.
  4. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Keyboard and Mousepad: paso 4, imagen 1 de 1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  5. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 5, imagen 1 de 1
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  6. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 6, imagen 1 de 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 6, imagen 2 de 2
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  7. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 7, imagen 1 de 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 7, imagen 2 de 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 7, imagen 3 de 3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  8. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 8, imagen 1 de 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 8, imagen 2 de 2
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  9. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 9, imagen 1 de 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 9, imagen 2 de 2
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  10. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 10, imagen 1 de 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 10, imagen 2 de 2
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  11. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 11, imagen 1 de 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 11, imagen 2 de 3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 11, imagen 3 de 3
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  12. Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 12, imagen 1 de 2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: paso 12, imagen 2 de 2
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
Conclusión
Blanche Pinto
Miembro Desde 09/28/17
437 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S3-G4, Nance Fall 2017 Miembro de USF Tampa, Team S3-G4, Nance Fall 2017
USFT-NANCE-F17S3G4
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 783
