Saltar al contenido principal
Asus Q552UB-BHI7T12 Battery Replacement
Qué necesitas
  1. Asus Q552UB-BHI7T12 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 Battery Replacement: paso 2, imagen 1 de 2 Asus Q552UB-BHI7T12 Battery Replacement: paso 2, imagen 2 de 2
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 Battery Replacement: paso 4, imagen 1 de 1
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
jorgealanhurtado95 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 3,323
